d17 diesel
one54dodgetruck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Topic: d17 diesel
    Posted: 02 Aug 2014 at 11:00pm
Friend just got a 1962 d17 diesel. The oil filter leaks around the top of the bolt head. What is he missing that is letting it leak? Is there a spin on filter mount that will work on his engine?
Thanks
Andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2014 at 8:00am
Here's the part number for the top center bolt gasket 74348266 you can get it from AGCO.
If he is looking to change it to a spin-on filter have him look for a oil filter housing off a D17 Diesel built after engine S/N 117087 or from D19.
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2014 at 9:20am
Thanks
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2014 at 11:14am
You can swap the older oil filter base with one from a newer diesel tractor. The series three and four and the d-19 had spin on filters and use the same filter as the 190 diesel tractors.
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
This page was generated in 0.058 seconds.
