need gaskets for 45
orangeman Ia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Ia Quote  Post ReplyReply Direct Link To This Post Topic: need gaskets for 45
    Posted: 25 Apr 2013 at 8:03pm
I need a cork gasket for the belt pulley , final drive gaskets, andgasket kits for the two lift  cylinders. Thank you.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2013 at 9:31pm
ck.with jim danforth at OK TRACTOR in mounds oklahoma,great man to deal with.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2013 at 9:32pm
 Lift cylinders don't have a gasket. They have a chevron packing which can be replaced if you disassemble the cylinder. They can also be tightened up if there is any adjustment left. They are available cheap from places like Motion industries.
 Some of the venders on here will have the Belt Pulley gasket and maybe the finals too????
You can buy cork from NAPA and such if you would want to cut your own gaskets. An exacto knife would do the job well.
