7020 toe?
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Topic: 7020 toe?
    Posted: 14 Apr 2013 at 12:00pm
the front end or our 7020 was set in the whole way and had a bad tie rod end. we got that fixed yesterday and set the width. how much toe in or out should we be running? they seem to be toed out a little at this point
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2013 at 12:13pm
Just measure the inbetween on the front of the tires and then the back of them and put them the same, should get ya there
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2013 at 1:47pm
so 0 toe?
tornado8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2013 at 2:35pm
I believe the manual stats up to a half inch toe is acceptable. I don't have it in front of me but I just narrowed up the 8010 a few weeks ago and I'm pretty sure that what it said.
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
