What brand of disk is this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Topic: What brand of disk is this?
    Posted: 23 Oct 2012 at 11:03pm
It is orange. Is is an AC or New Idea or what?
Here is the ad where I found it...it is not mine.
click here to see ad
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2012 at 4:26am
Kinda sorta looks johndeerish to me, like an rwa, kba, or something like that.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2012 at 5:44am
Looks like a New Idea to me. The hitch and where the hitch bolts up to the rest of the frame and the general shape of the frame. How the frame extends out each rear corner just a bit.
Edited by Lonn - 24 Oct 2012 at 5:46am
Wink
I am a Russian Bot
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2012 at 7:22am
It's not an AC.  Looks like Lonn wins the prize.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2012 at 9:03am
Lonn,
I had a New Idea sickle mower that was constructed out of big round tube like that, it was built like a tank!...that is why I suggested New Idea.
Pastor Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2012 at 9:05am
Would a WD pull it?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2012 at 10:04am
I think a WD will spin out trying to pull it in good ground with it working hard. I found a 6' disk was about right with my MF-135 with similar capabilities. I took an Oliver 12' disk, and remounted half the gangs as an offset disk and it was heavy enough to penetrate well and made a good load in plowed ground.
Gerald J.
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2012 at 6:28pm
Wd  8 ft. is about it .  10' is just a little too much need a wd45.  But all in how deep and fast you are going. Pitch (angle) you set the blades, and type of soil and conditions (wet dry etc.).
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2012 at 10:52pm
Thanks guys...that is kind of what I thought. I have an 8 foot dearborn disk I think now, it is 3 pt. I usually pull it in second cause my field is short. It has one gang that has a bent axle. I need to take it off and straighten it and I need to re do it somehow so that it will raise up off the ground farther when I have it all the way up.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2012 at 10:55pm
think Lonn is right...new idea used alot of pipe on their machinery! and parts of them were painted orange back then
houchens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote houchens Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2012 at 10:59pm
Looks New Idea to me too, guys.
8050 200 7010 185x2 D17-IV D15IIx2 D14 WD45 Deutz Allis 6260 Gleaner Kx2 Gleaner K2 Diesel 2300 discx2 600 and 333 planters 2 AC wagons several AC plows/chisels Rotobalerx2 Other Misc AC Equipment
