Chisel Plow size for a 7060
Alan (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alan (C-IL) Quote  Post ReplyReply Direct Link To This Post Topic: Chisel Plow size for a 7060
    Posted: 05 Oct 2012 at 11:14pm
Got all the corn out last weekend, did descent at 120 bu/acre.  Mom and I were brain storming what we could buy to reduce our tax burden and I thought a chisel plow would be a good addition.  I was trying to determine what size I could pull with the 7060 through silty clay soil.  My plan was to go with the chisel points rather than sweeps and I've seen anywhere from 4 HP/ft up to 10 HP/ft.  Does anyone have some insight they could share or know of any for sale near central illinois?  Seems the used chisel plow market isn't big around here.  Thanks, Alan
n7gleaner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n7gleaner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2012 at 12:27am
If you want an allis or duetz chisel plow 7 shank they pull very hard. if you buy a glencoe or a john deere or Kent chisel plow 9 no problem for a 7060 thats figure with disc on front.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2012 at 6:50am
I have a 9 shank Allis Min-Til and it' all my 7050 wants and more. I don't have any wheel weights on it but do have duals and I can't quite put it all the way in the ground without spinning.
Wink
I am a Russian Bot
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2012 at 8:45am
I pull a 6 shank,with 4"twisted shovels,14" deep,also has leveler bar,hard clay,4 Firestone Radials At 10# and get some tire slip,7060PS.
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2012 at 1:41pm
I pull a 9 shank Glenco with disks on the front with my 7080. In hard ground it works the tractor good. I have 20.8 radials with cast axle duals and 2 sets of the big wheel weights on each side and a full rack of front weights as well. Doesnt lack hp though.
Making a living farming with and working on Allis Equipment
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2012 at 3:07pm
back in the early 80's when dad and I were looking the rule of thumb was you needed 10 hp. for every tooth.
Life is tough,but it's tougher when you're stupid. - John Wayne
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2012 at 8:11am
  I pull a 15 shank Brilion with my 7060,Run 4th in hard tight clay, 5th in silt loam, with chisel points at 12" deep. Ballast filled tires, wheel weights, 20.8 duals. I ran some the other day to help level some old pasture ground we took in a couple of years ago. I got reminded why we no till now! I bet our fuel bill is cut by 70%! I put almost two tanks of fuel through it in a day. It's nice to get to PLOW and feel the power again.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
