d15 sreies II fluids
cobra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cobra Quote  Post ReplyReply Direct Link To This Post Topic: d15 sreies II fluids
    Posted: 01 Oct 2012 at 11:14am
checked the hydraulic/ trans fuid and found it to be thin and milky. is this normal or should i replace .i i dont no when fluids were changed if ever  . is there a proper fluid or will a generic brand do.  thanks
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 11:27am
Yes definitely change it as it has water in it. Use universal hydraulic/transmission fluid. I buy mine at TSC
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 3:21pm
There are 3 separate 'oil compartments' sorta between your knees:
Front one is Hydraulic Reservoir - holds 10 qts.
Oil level dipstick on R/H side near Belt Pulley.
Power Director - 8 1/3 qts.
Approx 1 foot forward of Transmission Shifter and to the left.
Large threaded nut with dipstick attached.
Transmission - 14 1/2 qts.
Located near transmission.
I use Trans Hyd. in Hydraulic and Power Director.
I use #80 in Transmission.
Gary
