Wc v-8 conversion?
Wayne1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne1234 Quote  Post ReplyReply Direct Link To This Post Topic: Wc v-8 conversion?
    Posted: 30 Sep 2012 at 11:14pm
Hello. Wondering if anyone has ever adapted a Chevy small block to a wc? Does anybody know where to find a adaptor plate for the bell housing? Or would it be easier to extend the frame rails and use the turbo 350 trans and couple that to the input shaft of the 4 speed gearbox? Any help or input on this topic would be greatly appreciated
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 1:02am
It's been done before.  There have been pics posted in the past. I think you will have to make up your own adapter plate as I don't think there is a supplier.  Hope someone else will chime in here with pics or you could try a search looking for WC V8.  I was going to do that but ended up parting out the engineless WC!
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 6:36am
Just seen one at the Jacksonville Ill. show Saturday. Had a "283" Chevy in it. Even rerouted the steering around the engine with a extra u joint or 2 and made a clean looking rig! Mike
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 8:34am
mike wish i new you were there i was there to. we could have met. i seen the wc v8 also there was a couple other v8 tractors there to. i think there was a massy 44 there with a   V-8.
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 10:51am
The WC and IH F20 are relativley easy swaps because you can use the motor and transmission combination of your choice and just couple the transmission to the original rear end. The Massey is easy because the transmission has a coupler in front of it so you only need to mate a shaft from that to the clutch. I have seen many different types of engines in these tractors over the years.
AGCO My Allis Gleaner Company
Dutchboy Johan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchboy Johan Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 9:50am
Not a WC, but here in the Netherlands there's a guy that converted a 305 Chevy into a ED-40.
[TUBE]qK-CqoC5uqU[/TUBE]
---> Better by Design <---
Johan Straver, Almkerk/ Netherlands
Allis-Chalmers 190XT Ser.III #26829XTD
This page was generated in 0.285 seconds.
