D17 FUEL TANK ?
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Topic: D17 FUEL TANK ?
    Posted: 23 Sep 2012 at 6:24pm
Will all D17 gas tank inter-change? i notice some have a strap that runs from the hood back to the steering wheel suport, the very earley D17 did not have this strap, mine is a 1959 and it dose have the strap, also dose anyone have a tank for sale mine has a dint in it. THANKS TOM
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 9:02pm
bump
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 10:54pm
Tanks are the same.  Just the strap for some reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 11:07pm
Give Ray O'neil a shout at 785-353-2392 in Beattie, KS as he usually has quite a few D-Series parts.
I've bought from him, he's a straight shooter and knows his A-C's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 11:17pm
THANKS GUYS....
Jess View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jess Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 9:06pm
No not all tanks are the same some have studs on the bottom side some dont I tried using a Series 1  1958 on a Series 3 1963 tractor and it went on but did not fit correctly you could see the difference if they were sitting side by side but it was hard to see if you did not know it i ended up fixing the original
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 6:38am
There was occasionally a problem with old tanks cracking on the bottom because there wasn't a strap holding them down. A kit was available to add this strap and usually, when you saw the kit installed, you could tell by paint color that the tank had been replaced too. I believe the strap had a u-clamp attaching it to the steering wheel column tube, where the later factory installed straps were welded.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 7:47am
Mine is a 1958 and has the U clamp as DR says
1968 D15D,1962 D19D
