Battery Cable
BobDinNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobDinNC Quote  Post ReplyReply Direct Link To This Post Topic: Battery Cable
    Posted: 18 Sep 2012 at 7:16pm
What gauge cable is used in a 6v system (CA) from the battery to the starter?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2012 at 9:45pm
At least 2, preferable 0 or 00. Nothing smaller than 2.
Gerald J.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 6:36am
For 6V, the norm is usually 1 gauge. But, this is one of the cases where bigger doesn't hurt. Some use welding cable which is a bit over the top, but it works. If the starter motor is in tip top shape as well as the Battery, the standard size should work fine.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 10:02am
Bigger in a battery to starter cable only hurts when its so big and stiff that it breaks off terminals on the starter or the battery post or can't be bent to fit. When you are drawing a couple hundred amps for a few seconds, its not wire heating that's the limit, especially at 6 volts its voltage drop.
Last time I needed battery cables NAPA had them in various gauges from wimpy to big enough for cranking an 800 cubic inch diesel in cold weather in various lengths without having to go to a custom cable.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 10:33am
I use welding cable (0 or better for long run) as the strands are small and extremely flexible. Having a large supply of cables from previous jobs makes it so I only need to find the ends , a good brass end-(cad plated at battery) with crimp ability and then solder to complete the bond.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobDinNC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 5:15pm
Thanks, Steve.  BTW the wiring harness you did for my D17 three years ago was well worth the expense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobDinNC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 5:17pm
Thanks, I'll check with NAPA to see what they have in stock here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 7:13pm
Glad you liked it Bob! Thank You! We also make Battery cables any length or size if interested...
Steve@B&B
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 7:20pm
Same question, but what if 6v nominal starter used with 12v battery?
Mark In WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark In WV Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2018 at 1:33pm
Steve,  I need a cable from battery to the starter on a 1952 allis CA....Can you help me?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2018 at 2:10pm
You can probably get by with a Big Box Store special, but I wouldn't. Throw a little more money at the cable and know you have a good one. Stick with 6 volt sizing. BTW, the positive post connector should be slightly larger than the negative. There are one size fits all connectors, but the good ones are properly sized for the post.
Edited by DougS - 31 Jan 2018 at 2:16pm
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2018 at 3:23pm
Personally, I'd use the same thing as I did for 6v because...why not?  However, decent 2ga would work, probably even 4ga...but why?
Edited by HoughMade - 31 Jan 2018 at 3:24pm
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2018 at 3:33pm
for 12V, I use premade 4GA cables. The 'trick' is they're premade,so properly crimped and molded making them more reliable than anything you bodge.
for 6V, I use welding cable,like others said very fleible and can easily handle the amps !
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 11:01am
How long is that cable?  I need one for my CA also.  The one on it is a cheapie but I can't measure it because it's up at the farm.
Thanks for the info.
