Need Some Ideas
WEL(IN&TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WEL(IN&TN) Quote  Post ReplyReply Direct Link To This Post Topic: Need Some Ideas
    Posted: 12 Sep 2012 at 3:40pm
How can I tell if my WD engine (201) has a WD45 crankshaft in it without pulling the head and measuring the stroke? Previous owner said it had a 45 crankshaft in it but I am not sure.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 3:51pm
Pull the pan and look at the casting number.  Will start with 226 if it's a 45.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 4:00pm
Should be able to take a spark plug out and put a piece of wire in there and see if it's closer to 4" or 4 1/2" stroke.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 4:30pm
The problem with the wire test is that the wire lays diagonal in the cylinder, andmakes the measuring challenging.
You could also measure displacement of 1 cylinder.  Good old fashioned liquid method.  Personally, I would just use it.  The when the oil pan leaks, look at the crank and then you will know.
JimD
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 4:33pm
Take a plug out like Lon says. You can use a heavy zip strip or a piece of wire to measure the difference in length from TDC to BDC. 201 will be 4 inches, 226 will be 4.5 inches.
