WD on Belt Pulley?
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: WD on Belt Pulley?
    Posted: 10 Sep 2012 at 8:48pm
How do you use a wide front WD belt pulley. Isn't the front axle in the way?
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 8:53pm
if it is drive over it with the rf wheel and then put it on, the top will be above and bottom will be below
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 9:05pm
On my 3 bolt front the bottom of the pulley is about a inch or so higher than the top of the front axle so depending on how high the other end was getting hooked up it could clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 10:51pm
We had a wide front D-17 with a belt pulley.Ran an old buzz saw and a cider press with it.Do not ever remember it being a problem.I believe on the D-17 the belt pulley was higher than axle so I am sure we ran over the top.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 11:43pm
Dig a hole for the right front wheel.....if it is a problem.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 6:01am
let the air out of the tires...lol
you should be able to have what ever you running off the belt pulley set up to go above or below the front axle.
