175 Allis Injection Pump |
Post Reply ![]() |
AllyCat ![]() Bronze Level ![]() Joined: 20 Mar 2010 Points: 14 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Sep 2012 at 6:03pm |
The "End Plate" gasket/seal on the pump is leaking. Tightened 4 screws, but no change. I guess I will send to pump shop for repair. To remove pump I believe there are some bolts/nuts under the engine timing cover that must be removed. Do I have to remove radiator to get to these? Also, will removing bolts/nuts allow anything to fall down into engine? Thanks for any advice.
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Just drain the coolant and remove the hose to get the cover off. There are bolts in there that have to come out in order for the pump to come off. Nothing will fall out of place....
ALLIS EXPRESS!
This year: |
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5097 |
It is uncommon to see a CAV DPA pump leak there. Usually it's the throttle & Shut-off shafts. Very simple pump to pull and re-install. No internal timing marks to line up, just the dowel on drive gear, and chisel mark on mounting flange.
Thanks guys, you provided the guidance and confirmation I was looking for.
Post Reply ![]() |
