1936 Unstyled WC oil pressure
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Topic: 1936 Unstyled WC oil pressure
    Posted: 05 Sep 2012 at 9:31pm
Whats the average oil pressure reading on some of your guys WC?
Mine is at R-M (NORMAL) when it starts after sitting for 2-3 days, after it warms up it drops to around the "O" at high idle, at low idle after its warm its at the N or belowe but still within the line on the gauge. Normal or not? Thanks
Leesok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2012 at 9:49pm
Sounds pretty good to me. Oil pressure is regulated mailly by the oil filter. Might try a new filter and see if it would help any, but in my opion I would not worry about it.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2012 at 7:02am
From what I've experienced, the oil pressure gauge on these is really not a good indicator of vital status... Others should weigh in their two-cents' worth here, but in my opinion, it's akin to judging the health of a bull by the length his tail.
I've kinda taken the position that if the gauge moves, that indicates that there's some oil pressure.  If it doesn't, then I listen for valve and governor noise... or pull the valve cover and see if there's oil flow at the top.
I think a more accurate and reliable indicator of oil pressure (and I think others may share the same opinion) is the dispstick... and here's how it works:
If there's no oil on the dipstick, you have no oil pressure.
If there's oil on the dipstick, there's a chance that oil pressure may exist.
If the gauge moves, there's a pretty good chance it happened because of oil pressure...
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2012 at 7:07am
I noticed last time that the pressure reads on the edge of 'N' on ours, and has dropped since 6 years ago. I am little concerned.
Galatians 5:22-24
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2012 at 7:13am
I wouldn't worry about it Josh
carl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carl Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2012 at 10:54am
Actually, that's better than most.  These are low pressure engines.  If you're getting oil at the top, it's fine.  Carl
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 11:14am
Thanks.
