Gas262 in wd45
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Topic: Gas262 in wd45
    Posted: 21 Aug 2012 at 6:33pm
Picking up a gas 262 and was wondering would it fit in a wd45 with 230?
if farming was easy everybody would be doing it
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2012 at 6:42pm
Somebody put a 301 Turbo in a 45 so I guess it comes down to how much work your willing to do.
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2012 at 6:49pm
Time, money and knowledge.
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2012 at 7:06pm
How 'bout a Fairbanks-Morse Opposed Piston diesel in a CA?  (no, I haven't done it...)
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2012 at 7:08pm
 Peice o' cake ..... If you have the WD45D adapter plate, flywheel and starter.... those are the biggies but you also need the  WD45D radiator, and unless your 262 came out of a D19, you will want the D19 governor and the D19 carb, the Zenith combine version is much larger , but there was a reason the tractors used a Marvel-Schebler.  Tractors Don't run wide open continuously.
 I have one in an unstyled WC, and that presented a little more challenge.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2012 at 7:47pm
I have the 45D adapter plate/flywheel and starter when your ready to proceed.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2012 at 9:23pm
Like this?
