WD middle steering shaft support. |
Josh Day
Topic: WD middle steering shaft support.Posted: 19 Aug 2012 at 7:51pm |
The middle steering shaft support that bolts to the frame rail underneath the gas tank is worn out on my WD bad. (as most of them are) is anyone making aftermarkets or is there away to fix it? Thanks Josh
ALinIL
Joined: 20 Sep 2009 Location: Frankfort, IL Points: 316 |
Posted: 19 Aug 2012 at 8:33pm |
The support can be bored and rebushed.
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 19 Aug 2012 at 8:41pm |
The one on my WC was wore real bad on the bottom side so I centered a shaft in it with silicone release agent on it and filled it with epoxy. The shaft was a little rough too and I drove the tractor on the trailer before adding any grease so it opened it up a little for me
but it still is way better than it was.
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 19 Aug 2012 at 10:14pm |
I bored mine out enough to accept a quadrant bushing
