7060 power shift
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Topic: 7060 power shift
    Posted: 16 Aug 2012 at 4:01pm
is it possible for hyd oil to transfer from rear-end to power-shift section?
dipstick in cab is over full and i don't remember adding any to it for a long time.
i have put a little in rear-end recently but i always have to occasionally, from hoses leaking and whatnot. this is on a 7060 black belly   thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 10:19pm
Yes, there are several places for it to transfer. Most likely place is hyd. pumps.   MACK
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 11:00pm
Yep, dad worked on one about a year ago with the same problem, it ended up being one of the pumps.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2012 at 8:50am
On our 7060 marroon belly pd it transfers oil between. Mechanic says its the seal between the rear end and tranny. Haven't got around to fixing it yet.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2012 at 11:44am
okay thanks,  i drained power-shift oil down to correct level, ill run it and watch it
maybe ill get lucky and someone just added 2 much to it.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2012 at 11:46am
Just out of curiosity what does it hurt to have the transmission a little over full? It says on the dipstick "DO NOT OVERFILL"
bigbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigbird Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2012 at 6:04pm
Had same thing on PD maroon belly, 7060 and 7040.  Like above, usually in pumps but could be seals between compartments.  We were always told that overfilling could cause seals to start leaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2012 at 9:59pm
I was always told overfilling didn't allow heat to disperse through the casting or something like that.
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2012 at 7:24am
Overfilling of the transmission causes heating because the clutch housing starts dragging in the oil level that's too high.
