plowing with 185
TimZ(TX) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Topic: plowing with 185
    Posted: 13 Aug 2012 at 1:25pm
I need to plow some rough pasture ground.  I found a fella with 2 AC  plows.   One is 4 x14" .  The other is a mono frame 5 x 16".  The land is hard blackland.   Can I pull the 5x16 or should I go with the 4 bottom.
Tim
CBL95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBL95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 2:03pm
Personally I would go 4-14's for sure especially if you say your ground is hard. Our 200 struggles with 5-16's in heavy bottom ground. I'd bet your 185 will handle 4-14's just about right. I've never been around a 185 but we have had 180's before. Just as a side note grandpa was looking at a new 180 that the dealer promised would pull 4-16's in heavy, heavy clay river bottoms and the dealer brought it out to the field and it wouldn't touch it, sent for a 190 XT, wouldn't pull it, sent for a 200, it pulled it barely, so he plowed the rest of the field with the 200 and he almost bought the 200 but a certain loved one would let him spend the extra money so he got a 180 and 3-16's. Sorry that don't have much to do with your question but thought I'd share that story
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 2:45pm
do your 185 a favor and look for a 3 bottom or knock off the back 4x14 bottom.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 2:59pm
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 3:07pm
Yeah I was dreaming,  The plows were the same money.   Our blackland here is tough.  I know you have to crawl with 2 x14 with the D 15.  Thanks
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 8:37pm
Using a d-19 I can plow just about anything with the 4-14's. Last year plowed hillsides when it was raining with duals on both sides it did okay for the steep hills from 15% to 23% grades on the hillsides.
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 8:42pm
185 will pull 4x16 3 point with no problem thats what we used (and the 190) until i got the 8050 and 6x16 semi mount. did pull 5x16 semi mount with the 190.... i perfer semi mount over 3 point ... just my opinion....Jb
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
