High RPM setting on a WD
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: High RPM setting on a WD
    Posted: 08 Aug 2012 at 5:32am
Hi
What should the high rpm be for a WD?  I remade the rod between the carb and the governor arm and also put a new throttle shaft in the carb and in total the rpm at wide open is 1550.
Should it be 1600 to 1700 with no load?
Thanks in advance for the help,
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 7:37am
  yes but 1/16 of an inch, could change it way too much. Do a search on here, lot's of good advice on this.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 3:40pm
I searched the existing posts and didn't find a recommendation on no load high rpm setting.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 4:57pm
If I am not mistaken the correct procedure for setting High Idle RPM on the WDs was to ever so slightly bend the throttle control arm on the carb side.
Still in use:
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 8:16pm
I had to set the linkage last year on my 45 after rebuilding the engine. According to the AC service manual
"Place hand lever in full speed position. Hold the carborator throttle valve wide open. The link rod should just reach between the cross shaft arm and carborator valve arm, or at most be 1/16" too long"
"High idle should be 1677-1722. If the speed is too high, let the throttle rod out at the bell crank, reducing the sprint tension on the governor."
