RC cooling system
GeorgeinNJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GeorgeinNJ Quote  Post ReplyReply Direct Link To This Post Topic: RC cooling system
    Posted: 03 Aug 2012 at 10:24am
  Finished engine rebuild. Filled radiator to just below overflow tube and started engine.
Success,it runs!! However, after running for maybe 5 minutes, water came pouring out of the overflow. Stopped engine to investigate and found water level in radiator just above
core.  lost abouit 2 quarts water because thats what it took to refill. started engine again.
Just starting to show increase in temperature, tank was still cool, and it overflowed again.
What is the normal water level? Am i putting in  to much water?
 This was a complete teardown and rebuild, clean block, new sleeves, new thermostat.
Am i missing anything? Any and all suggetions greatly appreciated as i am at a loss as
what to do next. Thantks, George
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2012 at 11:10am
My WD does the same thing. New rad and everything. It seems to set it's own coolant level in the top tank that it likes and stays there. It never overheats and has been like that for the 10 plus years I have had it in daily use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2012 at 11:14am
Use to figure 2" down from the overflow , this allows for expansion and for any air trapped in water to be relieved without creating a overflow.  Non pressure systems need that room.
This page was generated in 0.067 seconds.
