D14 that comes out of 3rd gear
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: D14 that comes out of 3rd gear
    Posted: 03 Aug 2012 at 5:38am
Hi,
I am looking at a D14.  It doesn't want to go into or stay in 3rd gear.
Is this fixable?  Does something need to built up or some parts replaced?   Want expense will trying to fix this cause?
Thanks
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2012 at 6:53am
Once the tran's shifter cover is pulled ,you can see more of what you might need .Expaese is alway's a guess until you know more . Anything can be fixed .
Edited by Fred in Pa - 03 Aug 2012 at 6:59am
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2012 at 6:56am
Everything is "fixable" with a thick wallet, others will chime in with some of the shortcuts -- the bigest culpret is the teeth on the shift collers also the fork could be bent or worn the shift collers mesh with teeth on the gears that are also probably worn. There is a saying out there that you figure $1000 for every gear it jumps out of. I know a fellow that bought one that jumped 2nd gear, he bought a chinese gear for about $200 and it worked great for two months and then was jumping out again but who knows if it the gear or if he needed to change other pieces while he was in there.
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2012 at 9:44am
Its about 1500 if you hire someone
This page was generated in 0.069 seconds.
