B brake help
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Topic: B brake help
    Posted: 01 Aug 2012 at 2:47pm
Putting brakes on my B today and realize there must be a proper order to put things together. No problem with getting the brake  band around the drum. Problem is with the brake spring. Any hints?
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 3:22pm
Take old screwdriver  and make a small notch in it   Hook top of spring first then push spring with screwdriver  from top and inside  near brake band, hook in hole .
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 3:26pm
Great idea, I wish I had heard that idea sooner... I think I gained quite a few gray hairs trying to hook them on my CA with needlenosed pliers.  You might also consider tying a string around the spring in case you drop it into the final drive.  I did that and it saved me alot of aggrevation, as I dropped the spring several times.
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 6:49pm
wfmurray, thanks for the tip, spring is on and I can do the other side tomorrow. Need to pull the wheel on the left side to get the pins in and I wanted to make the right side a trial run. Yes, different rims.
1C 1 WD45 1 AC180
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 9:55pm
I use the same stiff wire that I pulled the brake band with. Just double it and push it into the hole where the spring hooks to the housing and pull it down. Makes it an easy job. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
