6080 2wd to 4wd
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: 6080 2wd to 4wd
    Posted: 31 Jul 2012 at 9:19pm
Do all 6080 2 wd and 4 wd come with the same trans and rearend. Is there just a plug over where the front drive shaft output is. Is this doable If you had all the parts.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 11:22am
bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 12:43pm
Can't help,but while you're waiting,browse www.agcopartsbooks.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 6:28pm
Steve, I did spend some time on there, and was not able to get any info.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 7:18pm
yes they  are the same however on the bottm shaft from the trans to the ring gear the gear is missing there is 2 different spacers in there it looks like you would need to split her in half and install the gear and correct spacer then the gear box bolts on from the bottom
