8000 series with 5.9 cummins? |
Post Reply ![]() |
DarrylinWA ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Amarillo Texas Points: 1900 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Jul 2012 at 7:14pm |
Was there someone on here that put a 5.9 cummins in a 8000 series. Was it a 8010 or 8030?
What tranny did it bolt too? Was there adapter plates? Have a thought about putting a 5.9 in a 8010 tractor. Could I get to 7000 lbs? Did any Allis ever come with a factory cummins other than the 440. Had a lot on my mind after mowing lawn for 3 hrs. Thinking of a project to build in fall of 2013. Thanks in advanced, Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
The only AC farm tractor with a Cummins from the factory was the 440.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8635 |
Darryl you were supposed to out grow that daydreaming thing a long time ago.
heavy12d ![]() Bronze Level ![]() ![]() Joined: 06 Feb 2012 Location: mid MO Points: 10 |
I talked to a guy about 8 years ago who put a 5.9 cummins in an 8010. He said he loved it. More power and good fuel economy. He said he found a place online that he contacted and told them what he was putting the cummins motor in and they sent him everything he needed and it bolted in like it came from the factory that way. I am planning to do a cummins conversion in my 8010 this fall unless it will be too expensive. Good luck w/ yours if you try it.
MI8050 ![]() Orange Level ![]() Joined: 08 Oct 2009 Location: West Central MI Points: 226 |
Google that topic, there was a place in (Indiana?) that offered kits, lots of different ones. An 8.3 into an 8000 series must be pretty easy, i've seen lots of them done that way.
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4542 |
The guys building the kits and installing Cummins in A-C tractors are Hunleys who are former A-C dealers in Indiana until Agco didn't want them any more. Hunley's also have two of the originial 8090 experimental tractors. I know of a 8050 and a 7580 with 8.3 Cummins installed with their kits and the customers love the conversion.
Toscani NE SD ![]() Orange Level ![]() Joined: 21 Jan 2011 Location: Milbank S.D. Points: 369 |
someone put a 5.9 in a xt 190 for pulling around here with little effort,works good from what i hear
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
these people? This 8010 is for sale in VA, $15,000 with a 4BT ![]() |
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
this guy is putting a 5.9 in a 180 chassis! |
Charlie
AllisChalmers37 ![]() Orange Level ![]() ![]() Joined: 11 Jul 2010 Location: London,KY Points: 1846 |
With enough money and modifications you can put a Cummins in anything.
ac45 ![]() Orange Level ![]() Joined: 14 Sep 2009 Points: 395 |
I have a 177 hp b series hunley conversion in a 7060 and it does good. It is easy on fuel. I wouldnt want it set at much more thatn 120 hp in an 8010 though, a lot more low end torque than a 301 would have
Post Reply ![]() |
