timing marks on a 190xt fuel pump?
troy(el paso, il) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Topic: timing marks on a 190xt fuel pump?
    Posted: 30 Jul 2012 at 5:25pm
Hello All-
Have a question about the best way to go about turning over the engine on a 190xt in order to line up the timing marks on a Roosa fuel pump.  Just tried getting a wrench on the crank nut, but it's pretty tight quarters.  Any advice is greatly appreciated.  Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 6:25pm
Usually from the pump side or underneath , it maybe quarter turns but alot of times that mark is hard to see; or underneath the flywheel/clutch theres a hole for a big screwdriver etc to catch the flywheel teeth , then have someone watch
Edited by DougG - 30 Jul 2012 at 7:14pm
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 6:36pm
Troy I turned mine over from the alternator side carefully with the fan and putting tension on the belt. If you go past your mark I found I could not back it up, had to go around again. I turned the engine oner more revolutions than I care to remember! You can use the starter for some of it, but when the 25^ gets anywhere close you have to go really slow, and 4 eyes work better than 2!
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 6:42pm
Used the starter first to get it close in the window on the pump. Then I removed the starter and used a pry bar to move till they line up.    Bill
