WD45 #214756 made it home |
Post Reply ![]() |
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9653 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Jul 2012 at 5:30pm |
Jim Hancock ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: EL Reno, Ok. Points: 1112 |
Looks good from here! Way to go Thad!
Dnoym N. S. Can. ![]() Orange Level Access ![]() ![]() Joined: 03 Oct 2009 Points: 544 |
I've considered starting it with oil and antifreeze to diagnosing what you have IMHO B:-) Dnoym |
It does have a welded block behind the carb like wc's had. Are 45's bad about this also?
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Any block is bad about that if water is left in it and it freezes.
I did a compression check and got 150+ in all four. I don't know where to go next.
Why did the PO think it blew a head gasket? What symptoms does (did) it have?
Charley I really don't know. He said it had water in the cylinders. When I pulled the plugs he'd obviously filled the cylinders with oil. After we got it loaded his wife let it slip that it had set out and got rain in the motor but what was left of the oil wasn't milky white and it didn't have water on the bottom. I used the clutch in first gear to slow it down when I unloaded and the motor would turn when I let the clutch out. The starter was removed when I got it but i put it on tonight and did a compression check.
There my not be a thing wrong with it then if it got rain in the exhaust and was lubed up.
Goose ![]() Orange Level ![]() ![]() Joined: 07 Oct 2009 Location: Melrose, Wis Points: 2471 |
I wouldn't run it without some coolant in the system. Won't the water pump be damaged if there is no water or coolant?
JohnCO ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Loosen or take off the fan belt first. Could just be rain in the cylinders, hopefully the valves, etc. are ok.
Allis Express participant |
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3865 |
I'm with Charlie on this one, change oil fill cooling system and run it for a while to see what hapens. If oil looks good after that then leave it sit for a weak or so then loosen drain plug on oil pan to see what comes out.
When I got home today I filled it with water and a little antifreeze. I let it set a couple hrs and it was still full so I bought some cheap 30wt oil and filled it with oil. I cleaned the sediment bowl and drained the tank. I put in fresh gas and let some run out the drain in the bottom of the carb. I then tried to start it. It hit and popped a couple of times but wouldn't start. I pulled the plugs (champions) and cleaned them and washed with carb cleaner. It started right up and ran really good. The oil pressure went right up. Hydraulic fluid squirted everywhere. The hydraulic hose that goes to the left lift cylinder is missing. I made a temporary hose out of a cut up air hose. It made for a happy day. I drove it up the road a couple miles and back. The temp never got hot and the oil pressure stayed up. It runs really good. Now I need to get a hyd hose and drain all the fluids and change them. I was afraid to try the hydraulic lift because of the temp hose. The oil has no signs of water.
Boogerowen ![]() Orange Level ![]() Joined: 23 Apr 2011 Location: Mannford Ok Points: 431 |
It is surely good to hear that you are having a little good luck Thad......
Post Reply ![]() |
