diesel fuel tanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: diesel fuel tanks
    Posted: 16 Jul 2012 at 1:53pm
Had a neighbour ask a question..
seems he's heard that you shouldn't put diesel into a galvanized fuel tank.
Anyone else heard of this or know why ???
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 3:56pm
I have also heard this but don't know if it's true or not.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 5:00pm
Galvanizeing is a zink coating and it can flake off and clog filters, ruin injection pumps, injectors, ect.
You also are not sapposed to use galvinized pipe for the same reason.
We had a  generator set installed at our fire department and the plumber ran galvinized pipe for the fuel lines. after it was in for awhile i decided to read the operators manual in order to properly service it and it states in the book not to use galvinized pipe for this reason.
So far the unit has been oparateing for anout 6 years no problem so far.
The universal answer to all questions is yes, how much do you want to spend?
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 5:40pm
Here's what Page 120 of the Cummins install manual
http://www.cumminspower.com/www/literature/applicationmanuals/t-030_p115-132.pdf
says:
"Diesel Fuel Piping
Diesel fuel lines should be constructed from black iron pipe.  Cast iron and aluminum pipe and fittings must not be used because they are porous and can leak fuel.  Galvanized fuel lines, fittings, and tanks must not be used because the galvanized coating is attacked by the sulfuric acid that forms when the sulfur in the fuel combines with tank condensate, resulting in debris that can clog fuel pumps and filters.  Copper lines should not be used because fuel polymerizes (thickens) in copper tubing during long periods of disuse and can clog fuel injectors.  Also, copper lines are less rugged than black iron, and thus more susceptible to damage."
