This is why I'm doing a full rebuild
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Topic: This is why I'm doing a full rebuild
    Posted: 14 Jul 2012 at 9:51pm
Lost in the grease from a past bearing disintigration I found this metal.  on first inspection everything looked good, grease even looked and felt ok. However when I clean out the grease from the hub assembly I found this.  would not have been happy to have a new bearing take in some of this.
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2012 at 12:33am
Nasty!
CT
2014 LS P7010C, 1962 Farmall 504 Diesel (1st tractor) w/ 2008 Koyker 220 FEL, 1968 Allis Chalmers 180 Diesel, Komatsu PC38UU-2 Excavator, Various attachments for all!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2012 at 8:05am
I'm finding that even the oil is pretty gritty, when washing the housings out. After years of hard working a lot a metal has become a part of the system.
This narrow front end design does seem to be the weekest link in the tractor.  here is a picture of the shaft.  This won't be a cheap fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2012 at 8:07am
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2012 at 8:14am
If you have to break something down and decide to save money by not replacing something you automaticall end up spending twice what you thought you saved. That's my experience anyway.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2012 at 10:16am
+1 on the full monte. When I went to replace the lower seal on my D17 steering gear, I couldn't believe the amount of crud that was inside there and that it hadn't managed to destroy the P/S pump.
