7060 Rebuild Ahead.
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Topic: 7060 Rebuild Ahead.
    Posted: 11 Jul 2012 at 9:26am
I think I'm about to bite on a 7060. My uncle farmed with it before he passed, but it's got problems with the turbo and the engine needs overhauling. His sons ran it for a while, but haven't been considering the overhaul. I figure one more tractor for my 50 acers is about right. I'm going for HP per acer. LOL...
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 10:13am
What trans does it have and would you do anything to it just because youre there? I have a 7040ps on 40 acres with good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 11:58am
I'm not sure about the trans. There aren't any problems with it that I know of. If there were I would fix it. I'm one of those that fix it all when I start. It's a weakness. I do it all so its just parts. The biggest engine I've done is a 2800, so a 7060 is a new venture.
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 12:09pm
I am going through this with a 180 on 50 acres.
CT
2014 LS P7010C, 1962 Farmall 504 Diesel (1st tractor) w/ 2008 Koyker 220 FEL, 1968 Allis Chalmers 180 Diesel, Komatsu PC38UU-2 Excavator, Various attachments for all!
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 12:28pm
The 7060 is pretty easy to overhaul.  If you have a good handle on the 2800 engine, the 3700 will be simple too, they are of course not the same engine, but very similar.  Don't you need a 4W-305 for that many acres!? :-)
Still in use:
acnh210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 1:24pm
I have a 7040 ps, an 8050 fwa ps, an 8050 2w with a loader, a wd and an awsome wife on 31 acres.
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 3:02pm
Nsula the problem you have is a 25 cent part that takes $1000 to get to. Seems you could pull one piston, rod, and sleeve at a time replacing the orings, rod bearings, and piston rings without pulling the block out completely. The problem with this is the possibility the sealing surface to the orings might be corroded, which would take a full motor pull and special machining operation to correct. Roll of the dice...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 4:03pm
E
I've got a D15, and 185 and now it looks like a 7060. Thats with a (close you eyes and plug your ears) a 8N and 9N Ford. There is D14 and D17 in the family just not mine. They are just next door. Most of the times the D14 and D15 get used in the garden.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 4:45pm
That is some heavy equipment for 31 acres!
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2012 at 9:08am
My wife isn't that heavy. LOL
This page was generated in 1.418 seconds.
