B/C engine oil lines to head and governor.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: B/C engine oil lines to head and governor.
    Posted: 10 Jul 2012 at 10:18pm
I need new oil lines. The short one from the oil filter area to the T fitting on head has sprung a leak. Rust got to it. I would like to replace the one going to the governor also.
It looks like a conical compression fitting. All I see in the stores are the double bevel "bead" compression fittings,  and too large in diameter.
What is it called, what size, where to purchase?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2012 at 10:57pm
I have some good used ones that i will sell. send me a PM or email me at mbsctt881@hotmail.com if intertested.     Thanks Matt
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 8:02am
You could also re-plumb using plastic oil pressure gage tube and fitttings.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 8:16am
McMaster carr has the lines and fittings. The Tee fitting will look a little different though.
My guess is most tractors have the lines plugged up and should be cleaned or replaced.
Edited by wkpoor - 11 Jul 2012 at 8:17am
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 3:53pm
You really don't want to change the tee in the head. It has the orifice to meter/slow the flow and could drop the oil pressure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 4:07pm
Thanks Dick, I didn't know that. If a guy couldn't find an original I'll bet it wouldn't be hard to install one. Find an allen set screw that just wants to screw in and drill the center. I just sold one of those tees a few weeks ago. I'm going to look at another to see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 5:03pm
I went out to look and that hole in the tee looks to me to be the same or larger than the tube. Maybe that hole didn't need to be any bigger because of the tube size. Either way I expected to see and real small hole if it was to control oil pressure.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 10:25pm
you can buy copper oil line and fittings in a kit at Advance Auto or Auto Zone, about $12.00. It has the correct ferules with it. I have used standard plumbing type 1/8" ferules and they worked OK. All you want to do is squeeze the ferule around the tube and against the fitting. The area at the nut end doesn't seal anything, it just presses. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 10:53pm
Is the Sunpro CP7584 the right kit?
The conical ferrules look about right.
That is a copper line kit, they also have nylon.
Is the ferrule at the governor a standard
"double bevel bead" type ferrule?
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2012 at 5:17am
McMaster has the lines in stainless only I believe.
The governor has the same ferrules yes.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2012 at 8:06am
At one time, Steve in NJ had made some of these up.  Don't know if he has any left or not or if he still makes them.  FWIW.
This page was generated in 0.093 seconds.
