Bigger Valves in a WC
Bruce Nelson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce Nelson Quote  Post ReplyReply Direct Link To This Post Topic: Bigger Valves in a WC
    Posted: 04 Jul 2012 at 9:14am
What larger valves will work well in a farm stock WC with a WD45 crankshaft and flat top pistons?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2012 at 8:10am
I would think some tractor pullers would know!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2012 at 8:34am
I do not know... but for your rpm and displacement,will bigger valves make a difference? I got the impresson that port and manifold work were more important,but I have been wrong before.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2012 at 11:48am
You are correct. Port and polishing will give you an improvement and without it larger valves will not do much.  The porting will come first in any case.
