5ft or 4ft Brush Hog for CA
bitburn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitburn Quote  Post ReplyReply Direct Link To This Post Topic: 5ft or 4ft Brush Hog for CA
    Posted: 03 Jul 2012 at 11:23pm
Just ordered a Wishbone Category I 3 pt pin hitch for my CA.  Now I am looking to buy a new brush hog mower.  I will be using a slip clutch and over running PTO.
The question is, can a CA properly handle a 5ft mower, or should I go for the 4ft?  I am leaning towards the 4ft due to the thick brush and not wanting to tax the motor, but a 5ft would be nice.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 6:01am
4' won't be wide enough
Charlie
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 7:34am
i would go 5'. i have a 6' behind a c  and i think its a little much when i get  into really tall thick grass so when i do i use the wd45, i would only be worried about how heavy the mower is it. might have to add weight to keep the front down.i've been using this style and like it alot.
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 8:53am
I just bought a 5 foot Woods for my CA and it handles it pretty good. I would not go narrower.
Leon B MO
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 9:29am
I'd go with a 5 foot model...it will cover the width of the tractor and your actual cutting area will be about 4' (after the first round) if you overlap the cut to clean up what the rear tire flattened on the previous pass. I see a lot of fields where operators try to cut the full width of the machine, and a day later there are rows where the grass has stood back up.  If you mow with a little overlap you will have a much nicer looking field when you are done.
ALLIS EXPRESS!
This year:
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 10:50am
I wouldn't think that u would be able to lift a 3point brush hog with that small of a tractor. I guess that would depend on how heavy the mower was and whether u need to put more weight up front or not.
Can't fix stupid
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 12:14pm
lose the top link and you will do fine. never used a top link with the hog behind the wd45
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitburn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 8:10pm
Thank you everyone for the input.
Sounds like getting the five footer is the way to go.  I am not planning to lift the deck, but  I am putting front wheel weights on my shopping list though.  I should be picking up the 5ft next week.
T.J.-N.J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T.J.-N.J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2012 at 8:27pm
I use a 5 foot on my C but the CA has better hydraulics and can lift a lot more than a C. With my wheels all the way in the 5 footer is a real good fit and edges pretty good too but it does get a little loose on the front end. T.J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2012 at 10:32pm
I have a 5' snap coupler mower that I have run with my CA. You will want some extra weight on the front with a mounted mower. The CA has enough power, just can't mow in road gear...
This page was generated in 0.168 seconds.
