Finish for adjustable 125 fan pully
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: Finish for adjustable 125 fan pully
    Posted: 01 Jul 2012 at 10:13pm
Those two presicion pressed pully halves are very tight fit. How/if/what should they be painted? Currently there is no paint, but maybe it was removed in previous
paint job. I think any paint build up would prevent them from re-assembly.
Perhaps a grease or anti-sieze compound?
I remember a mechanic  heaping foul words upon a International tractor's adjustable
fan pully. "Dam metric threaded, rusted up, British made hunk of crap" A lot more F-bombs were launched, but I couldn't do it justice.  35 years later when I see a red tractor, this is what I think of.
Thanks, Brian
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 10:21pm
Those can be aggravating little rascals. I have one that I smeared a little antiseize on before I put it together. I think if you were wanting to paint everything up nice, you could go with the copper antiseize and wipe off everything on the outside that would be painted. You might still have to break up a little paint if you ever had to adjust it any, but it wouldnt be that hard to touch up. I usually just adjust it in to the point that it gives the belt a little room to wear without touching the flat at the bottom, then find a belt that I have to almost stretch to get on with the genny adjusted all the way in. Then you have some adjustment without messing with the fan pulley. I'd change the belt out before I messed with that fan pulley too much.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
