WD45 DIESEL WITH A 230 6CYL.
Brian in WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian in WI Quote  Post ReplyReply Direct Link To This Post Topic: WD45 DIESEL WITH A 230 6CYL.
    Posted: 01 Jul 2012 at 5:10pm
I BOUGHT THIS TRACTOR WITH ENGINE IN. WHAT I WANT TO KNOW IS HOW TO HOOK UP  AND DO I NEED FROM CARB. WITCH YES ON RIGHT SIDE TO THE THROTTLE LEVER WITCH FOR THE DESEIL ENGINE NOW. THE ENGINE WAS FROM A COMBINE I WAS TOLD. ANY HELP OR PICTURES WOULD BE GREAT. IF SOMEONE HAS ONE LIKE TO HERE FROM THEM.
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 6:35pm
Well, by George, I have spent about 30 minutes trying to interpret this post, and I am going to give up, can't figger it out, so someone else smarter than me will have to do it .....
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 6:41pm
I believe he is trying to connect the throttle linkage up to his gas engine and has the parts off the 45Diesel engine. I think he might need a governor off a tractor engine nad probably some linkage parts also.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 6:43pm
i think what he is asking is,, the governor is on the left hand side of engine, opposite side of where throttle rod on wd is.  how would he hook up to make it work?
well i have a 230 and have comtemplated this,.. first unless is has a tractor gov. it will only run wide open or idle, not much in between.  I guess you would have to fabricate something to conect on left side of engine.  that is where throttle rod on D19 is.
and throttle shaft is wrong on combine carb unless it has been switched to D19 application?
someone has done this before, im only brainstorming.
good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 6:54pm
You basically need governor control stuff from a D19 tractor and probably the carburator too. The rod that goes to the injection pump can be remade to work.
