AC 185 Popping of 1st and 3rd
GHAcres View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GHAcres Quote  Post ReplyReply Direct Link To This Post Topic: AC 185 Popping of 1st and 3rd
    Posted: 30 Jun 2012 at 9:17am
I just picked up a AC 185 and everything works great except that it pops out of gear.  For 3 rd gear it will happen without a load on level ground.  I can work around that but while baling the tractor jumped out of 1st going downhill but also on level ground.  I read somewhere that there are adjustments that may help (adjusting the travel on the shifter).
Does anyone have more detailed info on how to make this adjustment or other possible solutions.
Thanks
Charlie (NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 9:21am
Not sure about the 185.  In the D-series tractors that would probably be a bent or worn shift fork not fully engaging the gears.  Pull the top off the tranny case and take a look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 9:21am
Might as well figure 3rd is gone and 1st will be if you keep using it and it keeps popping out. It wears more every time it pops out. It will cost, but splitting and fixing right is the answer in my opinion.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 10:15am
Popping out on the level with no load indicates that it definiitely needs fixing.  Worn shift forks are only one part.  Tear the transmission down and look for worn bearings and mashed gears on the input and output shafts.  I've had it done on my 175 and 190.  A teardown is the only proper way to fix it.
