D14 original headlight question
Steve(SEMN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve(SEMN) Quote  Post ReplyReply Direct Link To This Post Topic: D14 original headlight question
    Posted: 27 Jun 2012 at 2:33pm
Changed tractor to 12 volt. Does the light separate to change bulb to 12 volt or
is there a sealed beam that works to interchange. Its measures about  4 3/4 lnches.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2012 at 5:22pm
I never did find a 12V bulb for my 6V D14 headlights. Ended up getting CA lamps with 12V bulbs. Not original, but close.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2012 at 5:30pm
Never  could find sealed beam for my 14 . Son put 12 volt battery charger to it ,pulled lights to see if it was hooked up. Blew all  bulbs except one on dash .Its been blind for several years. I thank that no bulb is discontuied.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2012 at 8:44pm
Keep it on six volt, use the correct cables, keep things clean, and problem solved!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2012 at 8:57pm
I am looking for replacement bulbs as well.  No luck so far!
MBwcIll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcIll Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2012 at 9:11pm
It is hard to explain with out pictures.  We enjoy the 12V because we use our toy on a regular basis.  I cut off the bulb housing and inserted a halagon bulb on the reflector.  That way I can use the original housing and lens and have bright light.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2012 at 9:34pm
Agco had the original style 6V sealed beams about two years ago (last time I checked).  Be sitting down when you get the price though!  To my knowledge, no other sealed beam will fit these lights.
