B Wide Front End on CA
BJ70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJ70 Quote  Post ReplyReply Direct Link To This Post Topic: B Wide Front End on CA
    Posted: 22 Jun 2012 at 2:22pm
I bought a B with an adjustable wide front-end with the intent of using it to convert my CA from tricycle to wide.  However, once I got the B home I realized I jumped on buying the B before doing my home work; the forward attachment and steering are different between the CA and the B.
This leads to obvious questions:
Can the forward attachment bracket and other unique parts for a CA wide-front end be found?
Is the basic geometry of an adjustable B wide front-end close enough to be fitted to a CA?
Thanks for any help.
pumpkinman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 2:56pm
unbolt the front bolster from each tractor at the front of the motor. swap steering gears .and front ends. if you put the narrow front on the B you will have a narrow  B
JarrodACFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 3:14pm
Maybe I am being stupid, but I thought B's only had the wisshbone wide front, not an adj. wide front. Am I mistaken?
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 3:18pm
They were available with an adjustable wishbone and later and adjustable front similar to  the CA's.
Edited by CTuckerNWIL - 22 Jun 2012 at 3:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 3:22pm
Ok, that makes sense, I just thought that B's with a adj. wide fronts were robbed off a CA at one point or another.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 3:26pm
I'm not sure about this. But I think the CA narrowed all the way will still be wider than the B front end. That could essentially make the CA useless.
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 4:53pm
Adjustable B WFE adjust from 40 inches to 65 inches.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 6:23pm
Unless you change the steering box below the gas tank. it will steer backwards. the gears are cut backwards. at its widest seting it will be just wide enough for a narrow setting on the CA rear. my sugestion is don't do it. you will wind up with a cobbled tractor. either find a C OR CA wide front, or keep it as a narrow front. Buy the way I have both a WF CA and NF C. I can't think of any good reason the switch one over.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 9:35pm
They don't steer backwards but you have to leave the CA steering arm pointing upwards. I have a C done this way with a B adjustable front. It steers better than any of my B's and turns sharper. It's at a tractor show right now but I'll get pics tomorrow and post tomorrow night. AC made a proto type called the b/c it's in Norms Book.
