Electrical question
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Electrical question
    Posted: 18 Jun 2012 at 7:15pm
Guys I would love to use my C to spray hayground instead of the 4 wheeler. C is stock 6 v and sprayer is 12 volt. But I may just get a pto setup. Ideas?
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2012 at 7:17pm
   Use the 190 instead. Then you have a radio too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2012 at 7:20pm
  OOps I forgot the 190 is down, but you get my drift.........
Cant really think of any other options other than maybe rigging up a Pto driven alternator?
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2012 at 7:25pm
how long would just a remote battery
last ? just an Idea
  B:-)     Dnoym
bauerd44 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bauerd44 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2012 at 9:19pm
I use my CA to spray weeds in the fence line using a 15 gallon tank sprayer that has a small 12 volt pump.  I have a 12 volt battery I keep for that spray job and for a 12 volt fence charger I use around the garden at times.  I keep it charged up with a trickle charger.
I can spray weeds for 1 1/2 - 2 hours on a single charge.  Works just fine for me.
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2012 at 9:46pm
Cap,
How much amperage does the sprayer need? If not a lot, you could switch over to a 12V Generator & VR to handle the charging chores and keep the Battery happy while using the sprayer. Done deal. I have a 6V Gennie converted to 12V ready to go on the shelf. Max. output 42 amps. Should be more than enough to do the job for headlights, tailight, & sprayer. Change out the 20/20 sweep ammeter to a voltmeter or a 60/60 sweep ammeter for safety. Loose the Headlight/charging switch, (they don't like 12V) and install a fused 12V Headlight switch. If its Mag fired, yer' done. If its Distributor fired, you need an Ignition switch and a 12V/3.0 ohm coil also to control power. We can fix ya up if you want to go that way....
