Wd/45 steering box oil
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Topic: Wd/45 steering box oil
    Posted: 15 Jun 2012 at 11:31pm
    The manual says to use 250wt oil, but it's impossible finding it.  What does everybody else use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2012 at 11:33pm
Cornhead grease would do nice. Then you don't have to worry about it runnin out the bottom seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2012 at 11:39pm
   hmmmm, you're probably right on that.  I better not tell the owner that he's got green grease in his orange tractor then!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2012 at 11:45pm
I used an Mobil EP grease we had at work. It's a little thicker than cornhead grease but if you pack some in the bearings it will work for a long time. I used the same stuff in my JD gyromower when the lube ran out the bottom of the gear box. Been in there 6 or 7 years now.
