D17 Series IV ?
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series IV ?
    Posted: 15 Jun 2012 at 8:16pm
Hello Hombres:  Did the 17  Series IV starter have shims between the starter flange and the bell housing as original equipment?  Having  a problem rolling the flywheel over with what appears to be a replacement starter.   Starter was on the tractor when I bought it.  Starter does not seems to what to engage.  So am thinking there is an alignment issue.
Thanks in Advance-Orangeman
Loren-ia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Loren-ia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2012 at 10:12pm
I have never seen that on any tractor. Have you pulled the starter and inspected the ring gear on the flywheel and the gear on the starter? Think I would make sure I had the correct starter for the tractor but also make sure that ring gear is okay or you'll just keep replacing starters and having problems.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2012 at 10:25am
never seen any shims on mine
