185 Hydraulic Issue
Davej View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Davej Quote  Post ReplyReply Direct Link To This Post Topic: 185 Hydraulic Issue
    Posted: 29 May 2012 at 12:22pm
Finally got Allis 460 loader mounted on our 185, not an easy task. Cannot see the bucket out of the cab when it is fully extended. After hooking up the hydraulics, we have discovered that the side two lever that controls the bucket will bleed off rather quickly. Does not do it when you change to side one outlets. Looking for answer as to next step in solving this. Really can dig some dirt with a 6' bucket.   Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 1:05pm
Sounds like you need to fix your control valve.
