Odd tractors and plows |
Post Reply ![]() |
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41979 |
![]() ![]() ![]() ![]() ![]() Posted: 26 May 2012 at 2:51pm |
Some odd 4 wheel drive units in use , early attempts for more power .
Then notice at the 1 min mark the push pull plow on the tractor , using both ends at same time, Two way plows also seem common .. [TUBE]http://youtu.be/aV3vUVaIgn4[/TUBE]
JarrodACFan ![]() Orange Level ![]() ![]() Joined: 24 Jan 2012 Location: Delaware Co. IN Points: 732 |
I am fascinated with european farming and how different it is from here in the United States.
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN |
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9878 |
At one time, my dad was seriously thinking about making a 4 wheel drive out of two D-17s. Kind of wish he had gone ahead and built one.
Lester ![]() Orange Level ![]() Joined: 08 Jan 2010 Location: Indiana Points: 521 |
My brother had a souped up UC Allis and souped up WD hooked up together, and pulled a six bottom plow with them. Later he hooked up two 40 Cockshutts with duals and pulled an eight bottom Oliver plow with it. We had to be careful on the turns because the back tractor would try to run over him. Ford tractors had a factory kit for Ford 6000's and other Ford tractors for a tandem hook up.
Roddo ![]() Orange Level ![]() Joined: 16 Jul 2010 Location: Brant, Ontario Points: 466 |
Here is a video of a guy in Western Canada that used to make these types of tractors for people before the articulated 4WD tractors caught on.
[TUBE]http://youtu.be/ZhULmjuk4cE[/TUBE] |
RockyBottomFarm ![]() Orange Level ![]() ![]() Joined: 16 Oct 2011 Location: Fall Creek WI Points: 253 |
last fall I was bidding on a John Deere R That was the second tractor from a double setup, needed alot of work and a front axle, it had long rods over the hood that went to the next tractor for the hand clutch and throttle. neat how people make some configurations.
My great grandpa built what they called a truck wagon/trailer it was a 2 ton truck frame that had the trans and rearend hooked up with the trans hooked to the PTO on the John Deere B. had a hydraulic dump bed. My grandpa said you could go anywhere with the biggest load even. They used to use it to go to the river and get sand for mixing concrete. they would shovel it full and drive home, went right up what we call the yellow banks.
38 & 41 B, sickle mower, 2 way plows, rear field cultivator, 2 row drill planter
40 Combine 66 Combine Roto Baler |
Post Reply ![]() |
