Allis-Chalmers Survey |
Austin(WI)
Joined: 11 Sep 2009 Location: Wisconsin Points: 1474 |
Topic: Allis-Chalmers SurveyPosted: 17 May 2012 at 1:02pm |
Hey Forum Members,
I made a small 10 question survey, just for fun, to gauge what is some of the main interests in the AC tractor line. I would appreciate it if you would take a min out to take the survey. I will post the results later! :) Thanks, AF |
"Better By Design"
David Gibson (OH)
Joined: 30 Oct 2010 Location: Hollansburg, OH Points: 493 |
Posted: 17 May 2012 at 1:23pm |
Done. There were a couple I would have liked to choose multiple answers.
FloydKS
Joined: 12 Sep 2009 Location: S E Kansas Points: 8538 |
Posted: 17 May 2012 at 1:37pm |
Likewise done...been too long since I have been on the farm so did not answer tha last one
Jim Lindemood
Joined: 22 Sep 2009 Location: Dry Ridge, KY Points: 2569 |
Posted: 17 May 2012 at 1:41pm |
Done -- also did not answer last one - would have just been a guess, not data based.
Josh Day
Done
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 17 May 2012 at 1:45pm |
Done
Austin(WI)
Posted: 17 May 2012 at 1:46pm |
The last two were just curiosity ones. I am interested to see which one people think are good/bad. I think I will make a follow up survey after this one to see why people think a particular model is good/bad.
"Better By Design"
Reindeer
Joined: 14 Sep 2009 Location: Calgary, AB Points: 655 |
Posted: 17 May 2012 at 2:20pm |
I agree, the last two to give an informed opinion, one would need a lot of experience. Some of the contributors could give valuable insight. My experience is too limited.
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3985 |
Posted: 17 May 2012 at 2:23pm |
Done
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34617 |
Posted: 17 May 2012 at 2:28pm |
1. learned to drive on a WD at age 6, orange had a sappy governor, and with the snap coupler and mounted equipment, it could go thru lots of places the drawbar equipment could not. hand clutch was the best thing too. Green was ok, but still liked the quick responses on gov of orange no matter if it was the fifty's models or into the seventies...190XT sat better, hydraulics better, power steering quick, rear ends and trannys did not hold up as well in early ones.
2. Love the steel, don't need to pump them up, hate the ride, jar your guts out on hard ground... Love rubber for smoother ride and actual more traction.
3. Love the styled and unstyled... the past and the present... which style are you talking about? the WD or the XT or the 1000 series?
4. Gas in the winter, easier to start, diesel in the summer, more fuel efficient, LP gas for cleaner oil and cleaner combustian and lesser headaches from exhaust... and a greater deterrent for theft of fuel...
5. Singles hop to much, would love to have my XT sittng on a narrow front. easier to get into tighter places, nicer for corn cultivation... wide front better for ride and safer...
6.Snap coupler had its unique advantages but harder tp hook up sometimes... 3pt is everywhere so more tools can be hooked up and go.
7. What era were AC's built the best? Depends on some factors... who likes what... I hate electronic gizmoes on tractor, simple mechanical controls and instumentation instead of sensores and computer controlled.. So hence the early part of 70's But the 1914-1940 were rugged old beasts that were just that rugged, 40's & fiftieswere little bit more refined and 60's &70's more refined and then the 80's... never got to own one of them...
8.What do you call small medium and large HP? Little B allis, had no time for them other than to cut yard grass and pull the hayrope or run a rake... Most of the work was done with WD-45, D17 then heavy work was 190XT , 1855 and 4520
9. 190XT III, 210/220.
10. worst ones? the ones gone to the scrap yards...
Well the survey was not conclusive enough for my thoughts... Like is fire good? It isn't when your house is burning down... but it is for cooking and keeping you warm...LOL
Austin(WI)
Posted: 17 May 2012 at 2:33pm |
It's an opinion based survey. No right or wrong answers.
"Better By Design"
R Aiken
Posted: 17 May 2012 at 2:37pm |
Done, I like steel wheels with rubber tires. Those rubber wheels are a little wolebly.
Ted in NE-OH
Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
You should have given us a choice of :" pin hitch"
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 17 May 2012 at 2:50pm |
Done
Wink I am a Russian Bot |
R.W
Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
Posted: 17 May 2012 at 2:58pm |
Done.
Burgie
Joined: 13 Sep 2009 Location: Scottsburg, IN Points: 1192 |
Posted: 17 May 2012 at 3:17pm |
Done
"Burgie"
JarrodACFan
Joined: 24 Jan 2012 Location: Delaware Co. IN Points: 732 |
Posted: 17 May 2012 at 3:33pm |
Done
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN |
Rfdeere
Joined: 11 Sep 2009 Location: Idaville, IN Points: 3283 |
Posted: 17 May 2012 at 5:11pm |
Since the parameters of the survey will not let me answer honestly, I will do it here.
1. Both Allis Chalmers Green and Orange
2. Both
3. Both
4. all
5. all
6. Snap Coupler ! Far superior !
7. all
8. all
9 and 10. There are a lot of variables to these two ? Different operators, environment, care, etc.
http://www.rumelyallis.com |
AC200Puller
Joined: 04 Dec 2011 Location: Wisconsin Points: 774 |
Posted: 17 May 2012 at 5:21pm |
Done
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2609 |
Posted: 17 May 2012 at 5:39pm |
My #10 answer was 'none' lol
Chris N Ky
Joined: 18 Sep 2009 Location: Milton, Ky Points: 13 |
Posted: 17 May 2012 at 7:12pm |
done- Fun survey
dave63
Joined: 01 Feb 2011 Location: Lineboro Md Points: 2382 |
Posted: 17 May 2012 at 7:16pm |
Yes to all but the last one.
The universal answer to all questions is yes, how much do you want to spend?
David G.
Joined: 21 Feb 2012 Location: W Nebraska Points: 1738 |
Posted: 17 May 2012 at 7:25pm |
All done
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 17 May 2012 at 7:30pm |
Done !!
Allis5020
Posted: 17 May 2012 at 7:40pm |
Done. WD-45 all the way! ;)
Austin(WI)
Posted: 17 May 2012 at 7:45pm |
Survey is closed! Got 100 responses exact! Just what I wanted! Thanks to everyone who participated. :)
"Better By Design"
