D12 square baleing
BIG MIKE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BIG MIKE Quote  Post ReplyReply Direct Link To This Post Topic: D12 square baleing
    Posted: 05 May 2012 at 4:39pm
Saw a series 2 D12 pulling a new holland 271 square baler today.It was going through the hay fine looked like it was a jurking ride for driver.I have a D12 just like it i did not figure the D12 pto system would hold up with the small spline pto shaft in the fly wheel.Ask owner about it he said he has baled about 800 bale a year for 6 years.Anyone else ever done this.I use a D14 with a square baler it handles a square baler fine but D12 I would be scared.Mike
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 5:10pm
My grandpa baled thousands and thousands of bales with an 8N Ford....I would think a D12 could take as much.....
ALLIS EXPRESS!
This year:
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 5:25pm
My father farmed many years baling 3,000 a year with a CA and never had a problem. The flywheel evens out the torque. Tractor going back and forth is the plunger action.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BIG MIKE Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 9:52pm
I know they have the power but looks like it would damage the pto on a series 2.I know mine will handle a sickle mower with ease.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 10:18pm
don't know about a D12, but a CA, D14 & D15 have the same size shaft coming out of the clutch. I would think that the D12 is the same.
 Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 10:22pm
I think Mike is thinking about the hollow shaft that provides the live pto for the D12.....the splines are fairly shallow and I have heard of them getting stripped. One of the reasons I would never put a heavy tiller behind a live pto D10/12, but the flywheel should help eliminate problems with a baler....like Stan stated.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote BIG MIKE Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 10:49pm
Yes its the small splined shaft that goes in the flywheel to give it live power i was thinking would be the problem.Never thought of the fly wheel balancing it out.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 11:06pm
I haven't seen it, but if you've ever seen 10 series fords, they have a small splined shaft that powers the PTO and hydraulics, and it'll wear out every once in a while, but it can handle 100+ hp through the PTO without a problem.
Hurst
1979 Allis Chalmers 7000
5800 Hours
