AC 8010 ENGINE PROBLEM
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: AC 8010 ENGINE PROBLEM
    Posted: 24 Apr 2012 at 7:59pm
Has anyone installed a 426 engine from a combine to replace the 301 in a late model 8010 with fwd. Appreciate any advise on what has to be done.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 10:16pm
do a search for '8010 426' on top of this page.  You'll get a post thats a week or so old with the same question.  Whats wrong with the 301?   -Wes
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 10:47pm
Connecting rod for number 5 broke and blew  a hole in the block. Engine is scrap.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 6:15am
Fred, I started a thread on this subject for John when he called. Do a search because there are some good comments.
Smokey Joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smokey Joe Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 12:42pm
I put one in a 7020 with minimum issues had to re-drill front plate mounting bolts to the frame rail and radiator had a little difference on the amount of cooling it had a bigger core. As long as you get one out of a tractor you would have everything. From a combine the rear plate,flywheel, and front plate will be wrong, oh yeah plus oil pan is flat with 2 sumps.   Get one from a tractor be alot easier. PM me I have lots of parts.
210,220,7010 AC,7020 AC,7040 AC,7045 Pedal Tractor, 8050& 8070 and Parts and Pieces of Many More!!!
This page was generated in 0.046 seconds.
