D-17 is being stuborn, next idea please
Dull Orange 17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dull Orange 17 Quote  Post ReplyReply Direct Link To This Post Topic: D-17 is being stuborn, next idea please
    Posted: 21 Apr 2012 at 2:52pm
The old girl (1959) is having a heck of a time starting, wants to fire every thirty seconds or 2 minute or so but just hits and then have to wait longer. There is Plenty if not to much fuel to the plugs, just tried a new dist. cap, rotor and points. still hard to start, crank, crank, crank. If she starts she purrs like a kitten, its just getting the kitten to start. Just had the Carb rebuilt last fall, tank boiled etc.
 if i pull the first plug I have fire she just seems like she is getting to much fuel and flooding the plug. i mean wet. Got her started today and fuel was coming out of the manifold. disc 3 acre's today, shut her off tried to start her same thing, hard to start.
Need the magic answer, could this be the coil, could the valves need adjusted. just looking for the next idea before i keep buying things I don't need. As you can tell, I am not a mechanic just know enough to get by. any advice would be appreciated.OuchOuchOuch
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 4:37pm
Too much fuel might be the problem if it's back washing out the carb inlet, you said fuel coming out them manifold? Sounds like a float problem in your carb or something in the seat keeping the needle from closing off fuel when the bowl is full. Plugs get fouled with gas if you flood it a couple times. Might take them out and burn em off with the torch and wire brush them. Even brand new plugs will do this if they are flooded a couple times.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 4:49pm
Yeah agree with Charlie maybe after running for a while shut off and look at plugs...should be dry. Float level [parallel with body]when turned upside down and make sure needle does seat w/o debris? Valves can be checked and set in 30 mins easily.
Richard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 5:11pm
Try cranking the engine with the spark plugs removed to see if gas squirts out.  I saw one time where the float in the carb just let gas go into the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dull Orange 17 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 3:11pm
Thanks Guys, I will take the carb apart and check the float level. i took it off the other day just assuming the float was sticking but never checked for level. I just emry clothed the float rod  and all looked good. I will try new plugs and adjusting the float. i have talked to to many people around home that are all telling me different things. I tought I would ask this group as you seem to know the best. Thanks again.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 4:12pm
Another thing to try is after you shut the engine down for the day is to turn off the gas.  See if it starts normally the next day after turning back on the gas.  The float valve may be leaking or not shutting off the fuel flow when the bowl is full and over filling the intake with lots of fuel.  Also if you have the carb apart is to inspect the float to make sure it's not got a hole in it that would allow it to fill with gas and make it sink like a rock, thus allowing too much gas to enter the bowl.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 9:54pm
The new needle valve may be letting gas past it. If the needle don't have a rubber tip on it, get one that does.  MACK
Mike(NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(NC) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 6:31am
I'm like Stan. cut the gas off before you shut the tractor off, then crank it as soon as you can after turning it back on.  If it cranks as it should the float is not shutting off the fuel.   Stan IL&TN View Drop Down
Thank God for another day. Thank Him for being alive and all my many blessings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 7:04am
If you take the carb off to check the float level, also check the drop. If it falls too far, it can hang up on the sides of the bowl and stick there allowing way too much gas in. Also while holding the top half upside down the float should be level with the gasket surface. Blow with lung pressure into the inlet and it should not let air through.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dull Orange 17 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 12:11pm
Thanks All, appreciate all the good ideas. I got her going and she is running better then ever, put new plugs, wires, ajusted the carb etc. I had also put new points, rotor, dust cap, condenser dist.cap. She basically got a good well deserved make over.
 I never cuss this machine, always talk to her nice and she never fails me. She was being real stubborn so she needeed a little attention I guess. All is well now and like I said she is running great. Thanks again for all the help.
