AC B Grill
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: AC B Grill
    Posted: 28 Mar 2012 at 12:19pm
What id the best way to remove the grill screen from the sheet metal. It is spot welded and I need to replace it and get rid of the remains of the spot weld.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 12:33pm
Carefully grind off the mesh from the back side. If you got steady hands, use an angle or die grinder. If not, use a Dremel with a good grinding stone. The Dremel will take longer, but is not as likely to produce an "oops!".
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
