180 PTO ?? |
Post Reply ![]() |
ctbowles58 ![]() Orange Level ![]() ![]() Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Mar 2012 at 1:28pm |
On a 180 when you put the PTO in gear it pops back out if there is a load on it ie. bushhog but if there is no load on it it will stay in gear. whats wrong? thanks for any ideals. Tom
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Skyhighballoon(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Tom - manual or hydraulic PTO engagement on your 180? Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
If it's manual read thru this prior post. Mike
http://www.allischalmers.com/forum/forum_posts.asp?TID=38937&KW=180+PTO+PROBLEMS&PID=295576&title=180-pto-problems#295576 |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8346 |
I bet there is an ear broke off the part inside the powerdirector housing on the linkage that slides the coupler to connect the shafts , go to Agco parts and check it out ; i had the same problem , that was the fix
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Linkage is the start of the problem. Don't engauge all the way then wears the front end splines off of pto shaft. MACK
Thats also true what Mack said , check all the linkage , prolly wore some
Edited by DougG - 10 Mar 2012 at 6:20am |
HagerAC ![]() Orange Level ![]() ![]() Joined: 14 Sep 2010 Location: SE MN Points: 1195 |
Yeah mine did exactly what Mack Said. Linkage gets worn, and the arm on the outside of the shaft can get a slight bend in it also. I just lengthened the bottom linkage about 2 inches and works like a gem now.
Post Reply ![]() |
