best primer for aluminum
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: best primer for aluminum
    Posted: 13 Feb 2012 at 5:42pm
I'm getting ready to prime some engine parts on my wc. What's the best primer for parts like the oil filter housing and other aluminum parts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 5:48pm
I'll be of no help and say, polish them. Makes for a little detail in a finished project but may not be original.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 6:25pm
epoxy primer sticks to everything
RickUP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickUP Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 6:58pm
Aircraft skin is aluminum, the paint does'nt fly off. Sorry I can't tell you where to buy it, or what it is. Just my first thought.
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 7:44pm
Zinc chromate, but don't ask me anymore about it.
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
amac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amac Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 7:50pm
Polish and get a spray can of clearcoat. Keeps parts from flash rusting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 8:07pm
Chuck is correct. Zinc Chromate, not easy to find here anymore. It is the best. Tracy Martin
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 8:21pm
I've had very good luck with PPG DPLF series of epoxy primer. It comes in different colors to match the paint application. For A-C persian, i'd use DP50LF Grey. It takes less paint to cover a lighter primer. The "LF" stands for "Lead Free", so it's enviromentally friendly. It also is good if you spray the part, then let it sit for a while. You just scuff it a little, and apply the desired paint.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
mark vaughn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark vaughn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 8:29pm
Zinc Chromate is what they use on airplanes and 18 weelers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 8:29pm
Thanks for the help guysSmile I found the zink chromate online at west marine but first I'll try NAPA. Next question should I reprime with regular primer before painting? I hope I don't have problems with chemical reaction with the paint.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 8:49pm
Here http://www.paintcenter.org/rj/jun05k.cfm is another option.  As it says, you won't find this in a hardware store.  Perhaps an auto body shop can help you.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 9:15pm
if you use zinc chromate do not use another primer,zinc chromate is the primer
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 10:04pm
Looks better not painted...just my opinion though.
