d14 question about tractor splitting
allis d14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis d14 Quote  Post ReplyReply Direct Link To This Post Topic: d14 question about tractor splitting
    Posted: 07 Feb 2012 at 7:49pm
hello everybody i have a couple quick questions about seperating the tranny from the power director. i have a 1957 d14 and i need to repair my pto shaft engangement. i think the pin might have broken because the lever just flops around i tried to pull the lever out of the tractor housing but i wont come out. so either pin is still stuck holding everything up or something else broke. i have yet to pull of the handcluch lever to look inside. i was reading my service manual and the information is pretty lacking.does the power director lever and housing cover come right off? if i have to pull the tranny does it just slide apart because manual states to pull the shifter and pull a set screw but the shifter is no where near the tranny bolts to the torque tube. my final question is on the snap coupler lift i know the pump is in the torque tube but how does it get the fluid to the ram is the an external pipe or is it internal of the tractor. and is there any thing i should be carefull about when i am splitting the tractor?
i just want to let you know all help is very appriciated
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 7:59pm
You will have to pull the shift lever off, pull the side plate off and remove the set screw on the PD shift fork.  Then you can remove the PD lever shaft.  After this you will have to remove the pin on the snap coupler and everything else that will interfere with splitting the tractor.  I just split a D-14 a couple of weeks ago and I had it split in a couple of hours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis d14 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 8:08pm
what pin on the snap coupler?
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 8:22pm
I think you can do the job with out splitting. I twisted      front pto shaft and took it out and and gears and put back . Worked through  hole in  side  and in front of pto gears, also pulled  rear pto .It is pretty close work . ps Mine is a 57 D/14.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 8:35pm
If the roll pin is broke in the PTO shift lever you will have to split the tractor to replace it.  While in there replace O-rings on PD lever shaft, and PTO shift lever.  The pin in the snap coupler would be the large pin that goes through the front of the bell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 10:18pm
Easy way to get snap cuppler pin back in is to push it out with 5/8 or 11/16 deep well socket and leave socket in snap couppler bell. When putting back togather push socket out with pin.(use socket same size as pin or a little smaller)  MACK
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 6:05am
Remember that pin is tapered, so it will only go one way.  Dave.
