sad night last night at pull
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Topic: sad night last night at pull
    Posted: 05 Feb 2012 at 7:46pm
Cry last night a d21 on alcohol caught fire last night at the miller coliseum murfreesboro tn iv got it on video ill post it later. any1 else see this happen, um tractor was called the entertainer i think, she was turning alot of RPMS
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 11:01pm
http://www.youtube.com/watch?v=kujZTQ66YDo&feature=channel_video_title this is one of my friends pulling a 6030 in 2008 he won his class he set the 6030 up on the sand pile, the D21 video is still loading like 30 mins left and she'll be up
Edited by acd21man - 05 Feb 2012 at 11:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 11:29pm
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 11:35pm
Yea I was there. He won the class Friday to make the finals. Only shot we had to see an orange one win. Other then that its a Christmas show of Red and Green. Really gets old seeing 6030s and 1466s pull at every pull, in every class, on every level. Really dont prove anything winning with a red or green one. Make the rules to fit,and bolt on what you need, and you can be good with a red and green one.
                                               IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 11:43pm
did you have a tractor pulling or was you just there
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 1:12am
From the video not a unheard of event on the NTPA circuit.  Amazing how fast the big boys of pulling can get a tractor back up and going.  Seen them before were they have physically split the block to the point were you could see a 4 inch gap.
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 8:40am
I tried to listen to the announcer, Did he say the tractor belongs to Al Koch of Indianapolis?
Tim-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim-tn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 8:49am
the D-21 was the Entertainer out of Indianapolis, IN. owned by Al Koch.
smuggler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smuggler Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 3:13pm
yes al koch and john lancasters tractor.  The rules are set up equal as far as cubic inch and weight. ! major problem is the old 426 block cant take the same abuse as the otr colors. The Entertainer  had valve train issues the other nite. And apparently was a little lean on fuel as It detonated. Not a huge deal.  Al and John are 2 guys that have been around for along time and are some of the best there is. there also 2 of 3 guys who were the 1st to put 4 turbos on a super stock pulling tractor.
bikley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bikley Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 3:23pm
[TUBE]3iQQ3rdmBAM&feature=channel_video_title[/TUBE]
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 6:18pm
Needs alittle bondo!
Greg Kroeker
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 11:28pm
I was there and saw it.. kinda disappointed as well since that was about the only orange, though I did see a 180 pull on friday.  The rest looked like a christmas display!    oh, and I wasn't too far from you as I was about two sections to the left at the very top of where this video was taken..       -Wes
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 6:25am
I've seen plenty of green and red ones on youtube that have split the block in two throwing the top 2/3 of the block up through the hood and on to the ground. I don't think Allis has any more problems than a red or green one. It's just that Allis has been gone for more than a generation now and that means fewer tractors and fewer with the interest to pull Allis. Back in the heyday of Allis in the 60's and 70's Allis was king on the pulling circuit. I was pretty small to see much of it but I've worked with older red fans that told me all about how Allis was the one to beat back then. Allis pullers were the first to put multiple turbos on their engines if I remember right.
Wink
I am a Russian Bot
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 7:35am
Looks like it went a little lean.  It is comeing down to who can hold the most pressure between the crankshaft the the block deck.  We can build girdles and run tie bars from the girdle to the head to add some strength. We can buy or build cylinder heads to feed any of these engines.  We can use large enough turbos and coolers to keep the intake temp and pressure in line and keep throwing methanol in to make up some of it.  But when one little thing goes wrong, parts go into orbit no matter what has been done to prevent it.
I hope it didn't lift the head or wreck the block, hopefully just popped the intake off and has some fire damage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smuggler Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 1:29pm
Neither me nor Al  run any kinda of tie system to hold the block together. We are not running the huge boost like the diesel tractors. In the light super class intercoolers are not allowed for a alchol tractor.  Al told me he thinks it dropped a valve then detonated. Not much any of can predict is when a valve is gonna come apart.
